Complete Balanced Rotating Assembly
sscamino
Complete balanced bottom end with very low miles excellent condition, Flexplate,Wiseco forged pistons 5040H3 30 over 3.830 bore pistons,stock length floating rods with ARP bolts,turbo crankshaft is 20 over on the rods 20 over on the mains and 10 over on the thrust bearing.Crank is still in box from machine shop fresh from machine shop.Ready to go $650. Also have rebuilt stock heads(done by a local shop that does nothing but heads) hot tanked, regular valve job and seals,new soft plugs,new comp cams LT1 springs,solid rocker shafts,and
new ARP bolts Heads have not been installed since rebuilt. All you need is a block and your good to go. $500. Will consider Fast set up or new SS Headers on trade.Will pay half of shipping....rbart1@verizon.net
