Scott89TTA
- Jul 12, 2005
What happened to the original "Combo/Time Slip" database that had all the car info and a list of rank against others?
Details of the run:
60'
330'
1/8
mph
1000'
1/4
mph
Member Name/Car
EMPTY WEIGHT:
BLOCK:
HEADS:
CAM:
TRANSMISSION:
TORQUE CONVERTER:
DIFFERENTIAL:
INTERCOOLER:
THROTTLE BODY:
RJC POWER PLATE:
INJECTORS:
THERMOSTAT:
TURBOCHARGER:
VALVE SPRINGS:
MAF:
DOWN PIPE:
EXHAUST:
FUEL PUMP:
FUEL PRESSURE REGULATOR:
FUEL PRESSURE:
ALCHOHOL INJECTION:
PROPAIN INJECTION:
NITROUS:
AIR FILTER AND AIR INTAKE:
TIRE DESIGN, SIZE & AIR PRESSURE:
AIR BAG(s):
SUSPENSION:
SCAN TOOL:
FUEL:
CHIP:
CHIP TIMING:
KNOCK RETARD:
OXYGEN SENSOR VOLTAGE:
EXHAUST GAS TEMPERATURE:
TRACK ELEVATION:
TEMPERATURE:
PEAK BOOST:
BOOST AT LAUNCH:
MILES ON THE CAR/ENGINE:
Details of the run:
60'
330'
1/8
mph
1000'
1/4
mph
Member Name/Car
EMPTY WEIGHT:
BLOCK:
HEADS:
CAM:
TRANSMISSION:
TORQUE CONVERTER:
DIFFERENTIAL:
INTERCOOLER:
THROTTLE BODY:
RJC POWER PLATE:
INJECTORS:
THERMOSTAT:
TURBOCHARGER:
VALVE SPRINGS:
MAF:
DOWN PIPE:
EXHAUST:
FUEL PUMP:
FUEL PRESSURE:
ALCHOHOL INJECTION:
PROPAIN INJECTION:
NITROUS:
AIR BAG(s):
SUSPENSION:
SCAN TOOL:
FUEL:
CHIP:
CHIP TIMING:
KNOCK RETARD:
TRACK ELEVATION:
TEMPERATURE:
PEAK BOOST:
BOOST AT LAUNCH:
