Hey ya'll. I've been chasin some problems with my 86 GN. I've had a sputter, lean pop, ignition issue of some sort hounding me for a year now. This problem occurred when i bought it but then went away until early last year and came back. The car runs great until about 15lbs. of boost and then it pops and all the boost drops and builds back......... I believe i may have it narrowed down to the Control Module/ ignition coil being the culprit.
The other day i tried to purchase a coil to try that and discovered the AC Delco coil #d552 has six spade terminals underneath that are straight down off the bottom. The original has those terminals bent 90 degrees for the wires that attach to them from the control module. Is that the right coil????? or is that made for a revised control module that those straight blades would plug into rather than the one with the six wire leads. Is that wording confusing??? lol
At any rate, does anyone know where i can buy a new coil and controle module that MATCH??? please help.
