code 43
dadmomcat
Has any one ran into a code 43 problem ?? check wiring and plugs at ECM and ESC module. Base on the knock gage, i will get into the last red at WOT and start to get green lights at 7 lbs of boost. Can the Knock sensor be bad ??
Also car is running really rough at idle, gets alittle better after 1500 rpms.Before all of this stuff, Car has been running great, i'm getting alot of strange stuff, Fan motor will not shut off, relays are ok, then fan would be ok, Bad heated o2 sensor, looks black soot after only 2000 miles, can they be cleaned ???
I have alot of question here, thanks for any help out there.
