usetaboost
SAY CAR RAMROD!!
- May 4, 2005
Any way I could figure out what's going on with these without a scan tool? CHecked fuel pressure with key on is right at 40 psi. with vaccum hose off regulator I got 47 at idle, seems kinda high. When I was driving down the highway at 60 I had about 3 boost at steady throttle, according to the "ACCURATE" digital guage, is that a sign of bad wastegate solenoid? As far as the lean code goes would a clogged fuel filter cause this? THe car sat for a while I think maybe it could be a little restricted from all the bad gas and whatever else. I have ran fresh gas through it just haven't got around to checking the filter yet. Also noticed my MAF looks a little dirty, can I clean it with brake clean? As far as mods go I got a 237 regulator, k&n 9" cone, 204-214 cam, bypassed coolant lines, and I don't have exhaust past the dual pipe yet and I"m still running stock ungutted cat.
