P plcguru Member Joined Aug 21, 2008 Jan 17, 2009 #1 Hi, A spring(governor, I believe) in my ck shift kit is bent and a little mangled. Is it still ok to use? Thanks
C chris718 Active Member Joined Dec 10, 2002 Jan 17, 2009 #2 Rework it by hand and put it in .If you are not ok with that ,give us a ring and I will send a replacement.
P plcguru Member Joined Aug 21, 2008 Jan 17, 2009 #3 OK, I'll rework it close to straight then. I just wasn't sure if it would cause me headaches with the governor if it wasn't perfect. (can you tell it's my first tranny build) For the record, it was perfect before I stepped on it... don't ask how
