joejakegrace
- Nov 9, 2004
Here's where I am - #791 with 17k. Had it 2 1/2 hears and it passed CT emissions when I got it (not by alot mind you but it passed).
Since then, new plugs, new pcv, new cat back exhaust (all required) and I replaced the K&N with a stock air box and filter I found.
Car runs reasonably well - occasional miss in mid range rpms.
Emissions yesterday - test 1 = blew HC by 5x the limit and CO by 2x. I took it home and put the K&N and original PCV back in - and added a bottle of dry gas. Took it back and it failed but barely - passed CO and HC was about 160/m when 120/m is pass.
Lead mechanic at the test station said he was pretty sure it was the mid range rpm miss. - He thought injector gunk or a mis on one plug - wire or plug.
Took it home and found one plug wire noticeably loose. Tightened it up and it seemed to lose 95% of the mid range miss. Took it back to emissions - FAILED BACK AT THE ORIGINAL NUMBERS!!
The only other thing I thought to change out as an easy fix was the )2 sensor - Tech said that might be part of it but it wouldn't blow the HC that bad. He's a pretty good guy and appreciates the car. Said he'd figure it out for me in an hour or so so that's what I'm going to do - I think.
Any other no brainers without dumping $ chasing things? I have a high end scan tool I use on my Formula that, for some nutso reason, won't even recognize the CPU on the TTA. I get "bad connection" readings. I plan on figuring that out this winter when I have the time but right now I have 30 days to get this thing fixed.
Any help would be appreciated.
DW
DW
