Is the spring on the stock tensioner weak? I pitched mine after my last cam change and now I was wondering if the tensioner every did anything more than just keep the loose slack of the chain in control.
I would think a camshaft, with all the valve spring loads, would have a tendency to dictate the slack side of a timing chain. For instance, if you had a timing chain that had some slack. Would the tension be biased to one side of the chain as went up the slope of the cam and backlash to the other side of the chain when you came down the backside slope of the cam? Or is one side of the chain always going to be in control of the tension?
I am just wondering since there are a lot of people running double roller chains and no one has a tensioner for doubles...therefore, I don't think all of them would fit like a glove with no slack, even with the slight varitions of timing gear sizes. If the cam moves with slack, then all the cam timing would be shot to crap!
