Catalytic Converter Heat Shield Hardware
ejones
Chief J
Looking for the nuts and bolts to mount a stock catalytic converter heat shield on my 87 GN.
if you are talking about the plate to the floor there arent any nuts and bolts
just little 9/32 (7mm) headed screws with integral washer
dont know how else to explain it , it goes on with short screws
the screws look like the screws that hold the fan relays on driver fender ....but shorter
The shield side near the door may take th 9/32 screws but the side near the tranny need something else to attach to those two brackets.
can someone post a pic i should have them in my box of hardware.
Pacecarta, I can see those screws you talking about working in the holes near the passenger door. If this shield attaches to those two small brackets close to the tranny, I must need something else.
best i can do with phone
the little screws with larger washer are the sheild screws the one in left upper is the screw for relay so you can compare
Was unable to open the pic, after looking under car again, you are correct about hardware. Thanks again
How about this pic of the one i took off my car when i replaced the floor. If you need these small brackets let me know ill throw in the screws also since im not going to use the shield. Heres a few close ups also
