I'm adding an MSD distributor to my car with old version FAST B2B. The Caspers deadend connector (plugs into CCCI connector to send crank sensor and cam sensor info to ECU) is apparently not passing the crank sensor signal to my ECU. I don't need the cam sensor / distributor mag wire inputs so did not install that little jumper - besides, the instructions for that are specific to the XFI harness anyway.
I am getting 12V at the sensor betwee A/B and A/C sensor connector pins but no rpm on CCom when cranking. Something's not right... has anybody here used the deadend connector in a setup like mine?
Art
Art
