Howdy,
Did they make a DIS control module that will run solo without an EFI ECM? I'm not hacking my bracket up for a distibutor since I don't plan on using one ever but I want to garentee my engine will be broken in correctly so I'll probably use my 4.1 4bbl intake to break it in then start sorting out the EFI system. There is too much crazy stuff I'm doing on this engine to do it all at once and I atleast want to make sure the long block is broken in properly before I start adding seriously custom stuff. Though I can't avoid my gerotor front cover since it takes block mods for that, but its mostly the same as a Duttweiler system so its a bit proven.
Thanks,
Thanks,
