Lock up not working....
that. or slipping clutches already?
chris,I am only looking for different ideas and opinions from other people on this site,besides I only thought you were on the trans questions section of this site!
yes external cooler and a 5 row radiatorStill using the stock radiator? I'm no expert, but i'd assume with an upgraded tranny you'd need upgraded cooling for it as well, like an external cooler?
changed the stat(160)flushed the coolant,seems to be flowing fine.How long ago was the last time you drove the car before installing the new tranny? Before Summer? Maybe the thermostat is sticking?
Chris at CK did the install also,he flushed the trans cooler and lines.Chris said the converter was fine,if it wasn't I had no problem with Chris putting in a new one.The trans before the rebuild was over revving between 1-2 shifts at WOT.I'm sure Chris did a fine job on my trans.I'm just trying to get different ideas on why the car is running hot.Chris and I spoke about a month ago and if I keep the car Chris will get her running good again.Like Nick said, Chris knows a lot about buicks than just trannys.I assume a new convertor was used along with the new trans build. How much room between the flex plate and the converter. I am assuming that you put the trans in and not chris(you did not include this info). If you do not remember having to pull the converter forward to bolt it to flex plate, then check your crankshaft end play. Just want to make sure of two things, the converter was seated into trans all the way and that the converter was not to big (ie ballooned etc).
Another suggestion is to get your hands on a digital thermometer. After driving around and getting things up to operating temp, stop the car. Open the hood and see what the temp is for coolant hoses and for tranny lines. see if you can tell where the extra heat is acoming from. This may tell you if it is the tranny or the engine.
Were any other changes made to the car at all?
How bad did the last trans destruct? Did you flush the tranny cooler or have it replaced?
