Since Im compeletely clueless about audio stuff I thought maybe a faq like they are running in the TTA forum would be great for people like me. Have the modorator post a sticky and then as people post questions they get added to the faq. Ill get it started
What is the difference between a 2, 4, 5, or 6 channel amps?
What does it mean to bridge an amp/speakers?
If you get a 2 channel amp, can you run your 4 car speakers and a sub on it?
Whats the proper guage wire for your pwr and ground for an amp.
Should you always put an inline fuse on your power connection to your amp, if so what size?
Whats the proper wire size for speakers?
Whats the difference between 4ohm and 2ohm amps and how does that apply to the speakers I have?
Whats the best (lightest?) type of material to make a sub box from?
Are there speakers and amps out there I should avoid becaue of shoddy construction?
Im sure there are many more Some of those (a few) I knew the answer to but Ill let someone else answer them thats 100% sure.
Dave
Dave
