turbotony1
- Mar 3, 2011
If everything goes as planned this week, I will be the proud new owner of a Stage II with M&A heads and a 76mm turbo. I will be looking into a TH 400 w/ brake and chromoly drive shaft. The rear end is my concern. I want it to be capable to hold up to low 9 sec runs off a trans brake. I don't know which way to go!
Do I keep the 10 bolt in it and put in good axles and an eaton posi or spool?
or
Should I use a 12 bolt or 9'' ready built stange or moser bolt in rear end?
Have any of you guys had good luck with the 10 bolts at the power levels that I'm talking about?
What is more cost effective in the long run?
Thanks for any comments,
Anthony
or
Anthony
