Ok, first I checked the EGR. I pressed the diaphragm in almost all the way for about a second. Definitely dropped the rpms a bit but I wouldnt say it made it stumble.
Now as far as testing the regulator, I made a new pump contraption with a gauge on it and hooked it up to the AFPR. Pumped about 15 psi into it and still was losing psi at a fairly quick rate. Still stumped me because I checked and double checked the "pump" and lines I made for leaks. They all held 100+psi of pressure. So I took out the soap spray and went searching for the leak. I found it at the top of the AFPR where the screw comes out, under the tightening nut. Now my question concerning this, is it normal? At this point Im a bit frustrated because Ive gone through 3 different contraptions trying to hold pressure. So I decide to see if I cant get a test out of it even with a pressure leak.
I turned the ignition on and heard the fuel pump prime, it pushed 12 psi of pressure to the rail. I waited about a minute max and the pressure in the rail dropped to 0. Turned the ignition off and on again, heard the pump again, checked the rail psi and it was now 25psi. Started the car after about 4 cranks. Tried raising the pressure to the AFPR with my pump with the car running and while there was a pressure leak to the AFPR, the fuel pressure looked like it rose according to the pressure I pumped. Went up to about 70 psi.
I was expecting to see it drop off around 50 psi, so I was surprised. Shut the car off and checked out the rail gauge. It was 42 psi. Went inside to get something, came back out maybe 4 minutes later and it had dropped to 35psi. So I decided to stand by and watch it. Another 5 or so minutes and it was at 30 psi or so. A few minutes later its in the high 20 psi range and I went to go look at something in my cabinet (which is 5 feet from the car), turned around and the gauge was at 0. Now my sense of time may not be perfect, but I can say with confidence that the psi went from 42 to 0 in a MAX of 15 minutes. So that seems like a problem to me. I've heard that the rail psi should hold for hours. If it doesnt its a leaky injector problem. Is there any way it could be a regulator problem? My injectors are brand new and have 600 miles on them tops. When I had my old 42lb injectors I remember I checked to see how long the rail held psi and it was only about 45 minutes or so, it was at least 2 years ago I checked that. (same AFPR)
Once again sorry for another essay, but maybe someone can make sense of this because Im just confused
