Ok, so Ive been chasing this knock ever since I got my engine rebuilt, and its driving me absolutely crazy. The rebuilt engine has everything in my sig and its all new except my fuel pump and fuel pressure regulator. Now the engine has a 9:1 compression ratio, so I expected to not be able to run a ton of boost, but I cant even get to 14lbs without knock. Another issue is if Im in 3rd or 4rth gear and I give it boost, even just a little, it knocks like crazy. Audible knock. I understand that the engine has more load, but it just doesnt seem right to knock from a 45mph roll.
I've been tearing my hair out looking for causes. Ive lowered timing, adjusted the air fuel ratio, reviewed logs of my runs over and over. There's one run where I lowered my timing to 14 degrees in 3rd and it still knocked.
Another small issue I have is when I start the car, it takes a long time to crank. Sometime I have to crank, stop, than crank again. It will always fire on the second try. When it fires though, the car surges at idle a bit and worse in reverse until you put it in drive, than its fine and totally normal. I used to have 42lb injectors and it did not do this, it only started doing it when I changed over to 60s.
Now theres a few things about the cause of the knock that Im not sure about.
One of them is if the AF ratio is around 10:8 consistent, is it at all possible for the cause to be fueling? Even though the AF looks good, would a bad AFPR or fuel pump cause knock? Also, is there anything in the valvetrain that could cause knock? Like lifters not working right, or anything else?
I would greatly appreciate any and all help in solving this knock, I cant get on the car at all because it always knocks and Im just not enjoying it like I should after all the money I poured in it.
Sorry for the essay, and here's a link to all the powerlogger files I have.
Powerloger Runs
Powerloger Runs
