S suprbuick7 New Member Joined Jul 19, 2003 Sep 14, 2003 #1 If solenoid is bad, will that keep boost from rising above 10 lbs.??
M mgmshar Active Member Joined Feb 20, 2002 Sep 14, 2003 #2 Yes, it could. If the solenoid is not working, it's like running the solenoid at 0 duty cycle, which means it's not bleeding off any boost signal to the actuator. In other words, your boost will be very low.
