Can I get some feedback on my first PL run with meth?
Brandon#
I recorded a PL file after I made sure my new alkycontrol kit was working properly. I also took a quick log of it idling.
Thanks in advance for taking the time to check it out!
fyi the IAT sensor was relocated to the up-pipe
  • runmeth1.dat
  • methidle1.dat
TT5.7 chip?
looks clean so far. no knock. o2's are high. Lean it out a bit, or give it some more boost. Off to a good start.
MAF sensor doesn't seem to want to stay pegged. Keep an eye on it, should hit 255 and stay there but you might need a bit more air flow to get it.
TT5.7 chip?
Yes, it's a TT5.7 alky chip.
I think my FP is set at 44-45 psi, I'll lower it down to 43 psi like Eric recommends and see if that gets my O2's down a little. Thanks for the tip on the MAF. I'll definitely keep an eye on it.
