My wifes 2000 Taurus wagon has 66K on it and it runs fine, no driveability problems, but it did sit for about 3 months without being driven other than me starting it a few times and letting it idle. When she went back to driveing it the car had a check engine light and since I have no scanner for a Ford I took it over to a local AutoZone where they will pop the code with a scanner.
The code showed to be an emissions evap code?? maybe it was from sitting, I don't know and once again no driveability problems. So the code was cleared and has not returned. Now here is the problem, after this was done I now get the air bag light lit and this happened right after the code clearing of the emissions code? Here's what happens, when you start the car the airbag light comes on and goes off like normal and when you drive the car and your mph goes above about 9~10 mph the light comes back on and stays on until you speed drops to less than 10mph or you come to a stop at which time it will go back out.
I took the car home and disconnected the battery to try and reset the ECM, this I did help and the problem went away for about 10 miles of driving and then the same syptoms returned again. Has anyone had this type of problem on a Ford, Thanks in advance for any help you can offer!!!!
Bob
Bob
