I've read several threads on upgrading spring-loaded camhaft thrust button to spring-loaded roller version when removing front timing cover. I bought a NAPA 9-5189 spring-loaded roller button for this purpose. Car is TR @ 135k with stock camshaft, and had stock cam button with plastic head.
A couple questions:
1) timing cover recess where stock cam button was located is 1.045" diameter, but new cam button is 0.740" diameter. Is the smaller OD button ok for larger cam button hole in the cover?
2) The old cam button wore a cone profile into the timing cover hole area. Some old TB.com threads recommend sanding or machining this area flat, while others claim this isn't necessary. I think the flat surface would improve the ability for the roller button to remain located in the center of the cam shaft rotation axis, but i'm interested in more experienced opinions than mine.
Thanks!
A couple questions:
Thanks!
