Cal or others... Magneto conversion
Fuelie Nova
OK... not a buick but I bought my XFI setup from Cal and have learned a lot from this board.
I want to convert a old Vertex magneto to a dual sync setup. Any thoughts? I hate to trash my fast dual sync dist for parts. Does anyone know of a supplier for the pickup and cam setup inside the fast dual sync?
Tom
Tom,
I can't remember your exact setup, but, it might be easier to throw a crank trigger on it. Then you could use an autometer inductive pickup that clamps on the #1 spark plug wire for a cam signal.
Cal and others
Thanks. I am converting a hilborn stack injection intake to efi. I wanted to gut an on magneto (just to have the old school look) and make a dual sync dist out of it.
I am looking for the cleanest way to get a cam signal, I was hoping to fit it inside the magneto body.
Tom
My pleasure. Don't hesitate to give me a call if you need any help phasing everything in.
Thanks... one thing I forgot about is the coil being on the inside of the magneto.... not sure how that might affect things :eek:
Tom
You are in uncharted territory so I can't say for sure how noisy it will be. A hall effect sensor would be better than inductive.
Well this just got easier... I called Joe Hunt magneto's and they will build a dual sync setup that works with XFI in a magneto base. Price aint bad either!
Tom
Tom,
Would this be the product mentioned above ?
Autometer # 5210 Inductive Trigger:
Auto Meter link to product
Would be great to use instead of a pick-up inside the distributor for cam sync, for use with a distributor and crank sensor for the XFI box
Thanks Cal, I soldier joints and use heat shrinkwrap tubing to finish off connections as a habit. Nothing worse than having electrical problems bringing the ride to the side of the road.
