mcgavinz26
- May 10, 2005
I went browsing a month ago or so for instructions on how to build a window switch but didn’t find anything. After realizing that it wouldn’t be difficult I decided to make one on my own. So I have one that works now, but is a little different. It doesn’t have a shut off RPM, but it only works above an adjustable range of throttle from around 80% to full and an adjustable RPM range from about 3500 to 5000 RPMs. So it will only work when you are on the gas and when you exceed the set RPM value. Total cost = <$10.
So does anyone know of a site that tells you how to build something like this on a beginner level? This is obviously all IC components with a handful of passive parts. No microprocessor.
How interested would any of you be in something like this? I needed something like this because I have a supercharger and a boost switch is useless to me since the car makes full boost at any rpm. I plan on making a write up on how to build it. You can use it for anything too, propane, shiftlights, whatever.
