Latest tests update
Well, I tried testing several more things this morning and still have not uncovered the problem. Here's what I tried:
- cam sensor - First I unplugged the connector and drove the car for a few minutes. Same result. Big time stumble between 2000 and 3000 rpm. Turned off car and tried to restart to confirm that I had unplugged the correct sensor. No start. Reconnected sensor.
Then I removed the cap and checked the reluctor ring. It was tight and seemed to be in the slot. Should the notch on the reluctor ring be pointed in the direction of the firewall ? After this I don't think the cam sensor is the culprit.
- MAF - started with a tap test. No change in the idle characteristics. Next, removed connector to MAF sensor. Still had smooth idle with no change. I guess this MAY mean the MAF unit is ok ? Still need to switch out with a known good one for further testing.
I really don't know what could be wrong at this point, but I have a couple of other things I suspect.
- Bad gas - I had just filled the car up within 20 miles of the problem starting. Stopped at a gas station I don't normally use.
- Fuel Filter - overdue for replacement. I will change this out within the next few days to see it makes any difference. I doubt this would cause the symptoms I am seeing.
- Bad coil pack - Still need to check voltage across the towers. I know this isn't a sure thing test, but if I don't see the right numbers, could be the problem. I don't have a Casper style tester for a real test.
Any other ideas ?
I live in Memphis, so when everyone gets home from the NATS, I will probably be giving Greg Friend a call for help. Greg, you out there ? He's been a big help to me in the past, and is a MUCH better mechanic than me.
