.If your broke like I'am or have other needs buy a set of heavy duty "stock style" rocker shafts and also use the shaft braces...I have both on my car....TA performance sells em and they are a reputable vendor..
+1 Just get a set off heavy duty shafts and don't overtighten them.sorry but for a 12.8 et car RRs are a waste of $$$
And for guys that like to buy 12 different lengths of push rods so they can hit the lifter pre-load spot on. With the original posters listed mods, roller rockers would be a good upgrade. Probably make a significant power gain due to getting the lifter pre-load right for the first time. Hardened shafts AND adjustable push rods will work, too. (unless you order the exact length push rod needed for each valve.) Correct lifter pre-load makes a significant difference on a turbo Buick. Off by .030" and it'll kill power. many times valve stem heighths are way off, then add thinner head gaskets, decked block, milled head, you have alot of chance to kill lifter pre-load. (.020"-.040") But Dan knows ALL this already. This is for everyone else. (He's been building shaft mounted rocker engines (FE Fords) longer than I have, and I'm NOT calling him old. Ancient, maybe, but not old.)I have used them on customers cars where they didn't want to bother adjusting them.. or getting bigger valve covers .. Lazy guys that just go racing
To adjust the adjustable pushrods I just measure ONE push rod before and after one 360* rotation to measure how much it moves. Then set it to zero and then add the needed preload. Same-O, Same-O. (Japanese for "the same thing") Just faster.
Yep.....Adjusting them with the engine IN the car is a PAIN for sure. Your way WOULD be easier if the engine is in the car. And getting the lock nuts tight really takes a high quality wrench (Snap-On) or the open ends flex too much. (3/8")I thought about doing that, but I found it a bit awkward to get to all of them in the car. I didn't have that warm and fuzzy feeling that I really turned it what I wanted and if it reversed a little when I tightened the nut. I said screw it and did it the long way. At least I don't have to guess if it's right.
I called Mike Licht and ordered a set of roller rockers. He recommended the 1.55 ratio, so that's what I ordered.
Considering you've gone big with all your other engine components it makes sense. I wonder why he recommended stock ratio for you. What turbo and stall do you have? also, what plans do you have with that motor out of curiosity? You've put a ton of work into it. It would be a shame not to push it hard.
The common 206/206 roller is a 9 sec cam. Running 1.55 rockers with springs that provide 135lbs on the seat and 380-400lbs open will allow you to run up to 5900rpm/30psi with no valve float. Running the 1.65 ratio would need a little more spring pressure to be able to do the same. It would take better heads to even see anything with more lift on this application anyway. You won't be anywhere near 5600 rpm with this until you throw a turbo on there and turn it way up.
