Broken 2004r
1936fordturbo
Hope to get into the high to mid 11s so I just added some bolt on upgrades to my 87 T-Type. I also decided to install a Transgo re-programmer to the stock 2004r. By the way the have horrible instructions with the kit. While doing so I found that the 1-2 accumulator spring was broken in half, probably the reason the car had a very poor 1-2 shift, the main reason I was doing this to the trans in the first place. So I was please I had found something wrong. Completed Friday the 8th after coming home from a long day a work. So I put the car in reverse and backed out of the driveway into the street put the car in drive and went out for test drive slowly letting the car shift itself. About a mile away for home I decided I felt comfortable to get into the throttle and see how the shifts felt. I was please the first 3 to 4 times and I had felt like I had accomplished what I set out to do ....until the 5th time when under full throttle it felt like someone had just cut the drive shaft in half. I did not hear any noises just the engine rpm rising as if I went into neutral. Lucky for me I was able to coast within a quarter mile from home where I walked to get truck and trailer. I am not a trans expert nor do I want to have trans rebuilt if I can avoid it right now. What, if any, are the know problems and can I (not a trans expert) accomplish fixing them? I was thinking input shaft?
Thanks for any help you may have.
Dave
Check your fluid level. Start it up and if the fluid level doesn't drop, you broke the pump. If that checks out ok, input shaft, O.D. planet splines, forward drum splines, stator splines. No matter what it is, trans has to come out for fixing. :frown:
Most likely the shaft on the forward drum. Been there too many times. Regardless, the trans has to come out.
Thanks for the quick posts Guys. I will be pulling the trans this Sunday and will post what I can find.
Dave
Found it!!!!
<a href="http://s857.photobucket.com/albums/ab132/davidkulka/1987%20Buick%20TType/?action=view&amp;current=IMG_20110716_202024.jpg" target="_blank"><img src="http://i857.photobucket.com/albums/ab132/davidkulka/1987%20Buick%20TType/IMG_20110716_202024.jpg" border="0" alt="Photobucket"></a>
Now do I just fix whats broken or go for the gusto !!!:rolleyes:
Time for a billet shafted forward drum.
Billet Forward Drum
Lonnie will fix you right up. Go ahead a dual feed the directs while you have it down. Lonnie can help you out with that as well.
Good luck
