I still have a pin hole leak, but that should not matter. The T76 should push 20+psi even if there is a small leak. Basically what happens, I adjust for desired boost. Pressure is meet, then boost starts falling as the rpm goes up after the pressure is meet. I have tried returning the controller, but the new one did the same thing.
If I get an electronic boost controller will the solenoid close the wastegate if boost starts falling off? I know in the long run a leak will cause max boost from being achieved or hold max boost, but I will never run the turbo hard enough to make max boost.
