The car seems to be running off of spring pressure only. I'm using an e-Boost 2 controller and no matter what I set it to I'm only getting spring pressure.
Got it figured out!! I might try to get out to Royal Purple this friday should be good weather.
I'm going to make a hit at the same boost (17#)) as before to get a baseline on the converter and log the run. Then I'm going to turn the wick up ... 24# i'm thinking.
I actually found a you tube video explaining how the e-Boost2 works. Very helpful. An Asian guy with an English accent tuning on an EVO. No the less it works, GOOD. Totally different car with real boost.
