No track time yet.what do u run in the 1/4. we have very similar setups?
Unless you use some sort of wideband tracking, a car tuned for 25 psi an say 11.0 A/F will start to lean out with the added air/ boost.why would it throw off fueling?
Further clarification, please.TT chips need adjusting as they are static fuel delivery at wot. Bailey chips read actual airflow at wot so if boost is raised, fuel will go up too. As long as you're using a translator and aftermarket maf.
Thanks for the replies. Learned something new about the difference between Eric's and Bob's chips that I didn't know before. Seeing as I have a boost controller, wideband, and knock reading capabilities, may have to give one of Bob's a try. Not to say I'm unhappy with my TT chip, just sounds like a fun way to learn more about tuning. Thanks!Just like it states. Bob splits the maf signal and can make a chip read wot airflow with an aftermarket maf and translator. He can double or triple the flow the ecm can read and thus, Bailey chips adjust wot fuel based upon actual airflow and not just static fuel delivery at wot. You still adjust the tune richer or leaner with the translator but once that's set, you can adjust boost and afr will stay the same. You need to adjust fuel with boost changes on a tt chip. Some like tt chips better.
