Went to a 1/8 mile track last night...
Running in OD, the car wont shift from 2-3. The RPM's just climb and climb until it starts to lose power or bog down. Letting off, then getting back on the throttle seems to help, but that is not a fix. Once it does shift, it is smooth and the 3-4 shift is fine.
The car shifts fine at 3/4 thottle. Only WOT runs are a problem.
I adjusted my TV cable before going to the track, could I have moved it to far?
I did manually shift on my last run, but it was my first time and the times werent as good (and I accidentally went from 2-N instead of 2-3, which really pissed my car off)...
My 60' times were consistently 2.0 and 1.9.
My 1/8 times were 9.2-9.8.
