After experiencing a horrible bout with blow by and replacing a worn turbo ,The car still blew plumes of oil smoke when it wanted to (most of the time )Finally measured the oil pressure on the 84 t-type im working on , at the turbo , startup oil pressure was in excess of 65 psi . wot was almost 80 psi when i asked the owner about it he mentioned the kenny bell hi flow mod had been done to the oil pump on the car . we changed the oil to a thicker 10w40 and added a valve to the turbos oil feed to bring the pressure down to reasonable levels , before this that tiny 4n line flowed enough oil to lubricate a 5 inch journal bearing !!!!! and we wondered why the turbos seal was leaking lol . Bam no more oil smoke . I do not recommend any mods to the oil pump on a turbo engine as this is what can result if your decision was uninformed . WE will replace the oil pump next year with a new stock one , this years season is toast . Misguided engine modders beware , the buick is one fickle , unforgiving machine that rarely gives up anything without a fight , but runs like a true champion when right
