headstrong3157
- Apr 1, 2005
I am currently having some BLM problems. At idle in open loop the BLM's are constant at 129 once it gets warmed up and switches to closed loop the BLM's peg out at 160. A couple of days ago I drove it for a short trip and under throttle the BLM's are around 129-134 but sitting at idle at a light they peg back out to 160. I recently switched to an Extender Extreme chip but before i unplugged the ECM to switch chips it had set an error code 13. So im thinking that its 02 sensor going bad thats causing me the problems. I am going to attach a word file that has my entire set-up on it and if I should post the rest of my scanmaster numbers at idle I will do it tonight when I get home from work. Any thoughts would be appreciated, I havent done the vaccum leak chase on it yet but will if I have to also could be a cracked header. Thanks in advance for any information.
