The overdrive carrier hub split and while upgrading to billet parts I saw that the Alto 4th gear clutches are black and the steels have some hot spots.
The trans only has about 40 passes, maybe 20 of which reached 4th gear. It had already been upgraded with 1 additional 4th clutch, what else can I do? Can I clean up the steels and reuse them with new clutches? Should I just plan on installing a zipper for replacing the 4th gear clutches?
BTW the parts are the same in both pics, used camera flash on the top one.
I do lock from 2nd on. It is not (not tagged) driven on the street. I just don't think this old engine should be inflicting this kind of mayhem.
I'm back to hating the 200.
