BIG PARTS LIST, Parting 2 more GN's!
Intercooled88s
Moderator
8.5 Posi rearend complete drum to drum 3.43 with driveshaft $825
87 GN Grill $250(no cracks or chips)
Blackout headlight bezels $80 for both
Blackout corner markers $80 for both
Front bumper fillers $80 for both
Rear bumper fillers $120 for both
86-87 GN concert sound lower door panels $100
85-87 Grey concert sound lower door panels $100
84 Light sand grey Concert sound door speaker covers $50
Concert sound door speakers with mounting brackets and wire harness $75
86-87 GN console $150
GN Dash Plaque(very nice) $100
86-87 Lower Intake(stock not ported) $170
86-87 Upper intake(dog house) $30
86-87 Fuel rail $35
86-87 Fuel inject harness $40
86-87 throttlebody complete(sensors,throttle lever, vac manifold) $90
86-87 Throttle bracket $40
86-87 throttle cable $30
86-87 Up pipe $25
86-87 Cruise control assembly $35
86-87 Water pump pulley $25
86-87 Crank pulley $40
86-87 Main accessory bracket $70
86-87 Y bracket on back of Alt $35
86-87 Flat Y bracket on front of AC compressor $35
86-87 Turbo bracket $40
86-87 Intercooler+ brackets $40
86-87 Intercooler fan $40
86-87 Coil brackets $40
86-87 Headers(factory Exhaust manifolds,passenger side needs rewelding)$100
86-87 Crossover pipe $40
86-87 Power steering res. $60
86-87 Power steering res. bracket $20
86-87 Power steering pump $70
86-87 Engine harness $250
86-87 ECM $100
86-87 MAF $80
86-87 Coil/ module $100
87 GN Grill, has a small chip in it, $50
Fresh set 8445 heads, not ported $100
NEW MSD 8.5 spark plug wires(84-85) $40
NEW IAC for 84-85 $30
NEW Power window motors $50 for both
86-87 T-type wheels $100 each
86-87 GN wheels $125 each
NEW after market header panel $80
Vacuum brake set up(master,vac assist and pedal) $65
Digital dash works fine $150
87 GN complete engine oil pan to throttlebody, MAF to ECM, runs good $2500
87 BRF tranny $500
Kenne Bell taller then stock valve covers $80
Turbo crank Std/Std $250
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
D-5 convert $50
Grey/chrome strips on upper door(that pull strap attaches) $35 each in good condition.
Nice 87 GN wheels $500 for all 4
Complete 86 T-type front clip(nose) $900 wont ship
Maroon buckets need recovering $120
Concert sound speaker covers(light sand grey) $60
84 Gold bucket seats $300 with rear seats $400
E mail me for any other tan(Gold) interior pieces have the entire interior.
84 leather and cloth seats(84 T-type) ,Sand gray, in good condition $300
Power master $190
Hydrobooster brakes $100
ENGINE from 87 T-type(complete from oil pan to throttlebody/Maf to ECM) runs good $2500
87 GN long block $800
BRF tranny $500
BQ tranny $300
Electronic climate control(complete set up, will even include dash harness) $200
Passenger remote mirror(needs paint) $60
85-87 GN Front and rear seats in good condition(power driver seat also) $500
Original GN fender extensions for car with spoiler(good black paint/has the blue on the inside) $50 for both
84-85 GN Front air dam(spoiler) $75
87 Turbo T(T-type) dash plaque $60
84 GN dash pad $100
84 GN steering column $150
Maroon steering column with tilt/cruise $150
87 GN Nice grey column with tilt/cruise $150
steering column Non tilt $90
Any color seat belt set(10 pieces) $100
87 locking t-tops $150
84-85 Non key locking t-tops $100
T-top bags $40
84 GN seats(Front leather/cloth with embroidered 6 with rear leather/cloth seat) cloth needs to be replaced but
leather is good $200
87 GN wheels(4) in nice condition(with center caps and lug nuts) $600
Header panel(T-type header panel with hole on top filled, GM not after market) $150
Kenne Bell valve covers with breathers $100
87 GN Electric fan $50
Radiator hold down(plate on top that hold radiator and electric fan) $40
New Cam Position sensor CAP $40
Complete 86 T-type front clip $800
GN front bumper $100
T-type header panel $150
T-type header panel with hole on top filled $150
GN spoiler (GM , 3 pieces) $175
Fuel cell $60
Shifter with T handle $50
ATR Ram Air box with K&N built into it(the box is made of alum) $40
Bigger then stock front sway bar $70
NEW Richmond 3.73 gears $90
Fuel sender/fuel hanger(analog gauge) $100
Hot Air to Intercooled Conversion: Includes parts to convert from 84/85 to 86/87 Intercooled setup. $1600
ENGINE PARTS:
AC compressor(84-85 AC compressor) $40
AC lines(86-87 or 84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $30
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Block(109 Block) $250
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $70
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(85-85 ECM) $40
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $35
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Injector harness(86-87) $40
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $40
Intercooler fan $40
MAF(86-87 MAF) $90
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(metal, frame mounts) $35
Oil pan(Turbo oil pan) $35 each
Power steering pump(86-87) $70
Pulley(86-87 Crank pulley with adapter) $40
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $30
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior parts except Green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Dash pad no cracks(grey or Maroon) $100
Dash plaque(87 GN) $90
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $80
Radio(Stock GN radio, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue
Visor(Nice blue passenger visor with lighted mirror) $20
Body Parts:
Blackout(Front windshield blackout trim(3) )$40
Blackout(rear window blackout trim(3) )$30
Blackout(Trunk Lid blackout trim piece) $35
Bumper(GN Front black bumper) $100
Bumper(GN Rear black bumper) $70
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Grill (86 T-type grill) $50
Grill(85 GN grill) $60
Grill Emblem(85-87 T-type grill emblem) $15
Grill emblem(87 , says "Buick") $15
Fenders(84-87 GN fenders(GM)) $80 each
Lock set(all 3 locks with key) $60
Quarter windows with blackout trim $80 for both sides
Tail lights with blackout trim $90
T-top black trim that the t-tops rest on(sort of L or boot shaped) $50
T-top boot shaped plates that the t-tops lay on $60
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror)$20
Windshield blackout trim(3) $40
Windshield chrome trim(3) $30
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $95-$150
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$35
Antenna base nut and spacer for Power antenna with black trim $10
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
PowerMaster(complete unit) $190
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Tranny dip stick and tube $40
Transmission oil pan(Stock 200 4r tranny pan) $25
Valve body(BQ valve body $200)
windshield wiper assembly $15
E mail Fortune628@aol.com
My cell number is 413 563 8819 reception at my new house is terrible. E mail or Pm's are best.
I will take it.
Do you have the bracket that supports the upper radiator hose away from the pulleys?
front bumper fillers taken? I'll take them as long as they aren't cracked...
PM sent
Are you willing to ship therse?? If so do you have any pictures??
