BIG PARTS LIST, Fall cleaning, more Parts added!
Intercooled88s
Moderator
Rear Spoiler(5 pieces) GM, NOT aftermarket $190 or $150 minus fender extensions
Original GN fender extensions for car with spoiler
Chrome 86-87 Res. cap cover $10
Chrome MAF pipe $20
Chrome up pipe $25
84-86 Power seat tracks $100
84-86 Power seat transmission $40
Complete 84-86 Power seat assembly $150
87 Power seat assembly $150
Maroon console $150
84 GN console $150
87 GN console $150
-84 Red upper door panels $80 minus chrome/gray strips $50
-Grey T-type upper door panels no chrome strips $50
85 turbo Riviera std block $200
87 Rebuilt long block less then 1000 miles on it (Postons cam) $1500
(4)Billet wheel adaptors 2 1/2 Make offer
(2)Billet wheel adaptors 1/2 Make offer
Grey/chrome strips on upper door(that pull strap attaches) $35 each in good condition.
Drivers side Blackout head light bezel $40
Chrome head light bezels painted black $40 for both
Marker lights $40 each
Blackout wheel well moldings $60 each
84-87 T-type header panel with hole filled $150
84-87 T-type GM header panel, has some small imperfections $125
84-87 Grand National GM header panel, has imperfections $125
NOS drivers side rear wheel well chrome trim $40
Passenger remote mirror(needs paint) $60
87 GN seat belt set(10 pieces) $120
-GN driveshaft $50
85 Turbo block bored .030, never used since machined $200
84 GN steering column $150
Maroon steering column with tilt/cruise $150
87 GN Nice grey column with tilt/cruise $150
steering column Non tilt $90
84 Gold bucket seats $250 with rear seats $300
84 GN seats(Front leather/cloth with embroidered 6 with rear leather/cloth seat) cloth needs to
be replaced but leather is good $200
84 GN rear leather/cloth seat $150
86 nice gray 86 442 bucket seats $200
Gray Monte SS seats $200
87 T Gray bucket seats $200
Maroon bucket seats need recovering $100
85-87 GN bucket seats need recovering $150
86-87 GN console $150
85-87 Gray console $150
84-87 Consoles I am using for parts, e mail me with specific pieces
Shifter without T handle $25
shifter with gray T handle $50
T-type billet shifter handle $40
85-87 Gray concert sound lower door panels $100
Blue Concert sound lower door panels $100
Concert sound speaker covers(light sand grey), just the speaker covers $60
Concert sound door speakers with mounting brackets and wire harness $75
GN Dash Plaque $75
87 Turbo T(T-type) dash plaque $50
84-86 T-type dash plaque $50
86-87 Upper intake(dog house) $30
86-87 Fuel rail $35
86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
86-87 bare throttlebody $40
86-87 Up pipe $25
86-87 Cruise control assembly $35
86-87 Water pump pulley $25
86-87 Crank pulley $45
86-87 Main accessory bracket $70
86-87 Y bracket on back of Alt $35
86-87 Flat Y bracket on front of AC compressor $35
86-87 Intercooler brackets $40
86-87 Coil brackets $40
86-87 Power steering res. bracket $20
86-87 Power steering pump $70
Turbo crank Std/Std $275
87 GN Electric fan $50
Radiator hold down(plate on top that hold radiator and electric fan) $40
84 rad shroud $30
87 GN long block $800
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
86-87 T-type wheels $100 each
Power master $170
Hydrobooster brakes $100
87 locking t-tops $150
84-85 Non key locking t-tops $100
Astro roof complete assembly with wire harness, switch etc. $200 wont ship
Astroroof parts, I have the whole set up but the glass is scratched up, E mail with needs
Fuel cell $60
Bigger then stock front sway bar $70
Fuel sender/fuel hanger(analog gauge) $80
87 BRF tranny $600
BQ tranny $300
Rebuilt BQ tranny $400
D-5 convert $50
Hot Air to Intercooled Conversion: Includes parts to convert from 84/85 to 86/87 Intercooled
setup. $1700
ENGINE PARTS:
AC compressor(84-85) $40
AC compressor(86-87) $80
AC lines(84-85) $40
AC lines(86-87) $50
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $35
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover)
$20
Block(109 Block) $300
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Coil pack(84-85) $40
Coil pack(86-87) $25
Control module(84-85) $50
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(84-85 ECM) $40
EGR plastic cover $5
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $35
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $40
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(metal, frame mounts) $35
Oil pan(Turbo oil pan) $40 each
Power steering pump(86-87) $70
Pulley(86-87 Crank pulley with adapter) $40
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Rock arms+shafts(stock, complete set) $35
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody bare) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior parts except Green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Dash pad no cracks(grey or Maroon) $100
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Vacuum brakes set up $75
Gauge cluster(Analog) $80
Gauge cluster(Digital) $180
Radio(Stock GN radio with cass, no EQ) $40
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red, Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue $20 for each
piece
Visor(Nice blue passenger visor with lighted mirror) $20
Body Parts:
Blackout trim for front windshield $20 each piece or $50 for all 3
Blackout trim for rear window $20 each piece or $50 for all 3
Blackout trim around the door windows $20 each piece
Blackout Drip rails(hard top) $40 for both
Blackout(Trunk Lid blackout trim piece) $35
Blackout trim, T-top boot shaped trim that the T-tops lay on $60 for both
Blackout trim, T-top center trim piece, that the t-tops slide into $70
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Front bumper shocks $25 for both
Rear bumper shocks $25 for both
Fenders(84-87 GN fenders(GM)) $100 each
Grill 87 GN Grill $200
Grill 87 Chrome grill painted black $125
Grill 86 T-type grill $50
Grill 85 GN grill $60
Grill emblem(87 , says "Buick") $15
Hood(GN hood) $150-$250 (pick up only)
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Lock set(all 3 locks with key) $50
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror,non remote)$20
Mirror(Passenger Mirror, Remote) $65
Quarter windows with blackout trim $80 for both sides
Tail lights with blackout trim $90
tail lights with chrome trim $70
Wheel well(Drivers Turbo plastic wheel well) $80 each
Wheel well(Passenger Turbo plastic wheel well) $100 each
Any other blackout piece e mail me I have them all
Misc:
Antenna( black manual antenna complete with mast, base and nut)$60
Antenna base nut and spacer for Power antenna with black trim $10
ATR vapor canister relocation kit(It mounts the cannister on the under side of the plastic inner
wheel well. $25
Control arms(Front lower)$60
Control arms(Front upper)$30
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Heater box shield $15
PowerMaster(complete unit) $170
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
86/87 Tranny dip stick and tube $45
Transmission oil pan(Stock 200 4r tranny pan) $25
84-85 T-type wheels $40 each or 4 for $120
84-85 GN wheels $100 each (no center caps) or 4 for $300
GNX Style 16 inch Wheels(Western wheels) $350
windshield wiper assembly $15
E mail Bob@bigpartslist.com or PM me.(Best way to contact me.)
Cell number is 413 563 8819 , I DON'T check the voice mail on this number ever. If I don't answer
just E mail me.
Hello Bob,
First in line pending condition. Can I see some pics of these.
Chrome MAF pipe $20
Chrome up pipe $25
cable guide, 86-87 lines
will take the cable guide. and depending on the 86-87 ac lines will take those also. are the lines the black nos lines and not bent?
center console parts
I am looking for the bottom section of the center console in good shape. Its a two peice design top and bottom. I just need the bottom in any color. Black would be nice but anything will do. Thanks
brakes
Hello Bob
I got a hot air conversion years ago from you now working on brakes
took off hydro boost
now looking for ideas
thinking of going to a vacuum setup ($75)
and looking for a MAF pipe chrome or not
what all comes with the brake set
Greg
gregmock84gn@hotmail.com
Hello Bob,
Chrome MAF pipe $20
Chrome up pipe $25
Res cover chrome is nice, MAF and up pipe isnt. I'll send some pictures tonight or tomorrow morning.
Cable guide is in good condition. I have a few sets of good used AC lines, I'll check to see if they have any bends.
I have a few consoles I using for parts, I'll check and see what colors I have.
any door panel etstions the pieces that cover the two bolts by strap.... four total...
sent email. I am looking for grey Locking T-top trim piece for Driver's side. It attaches to T-top. Also, looking for T-top trim square piece that goes in front of windshield and attaches to the piece that goes down the middle. Thanks.
