BFG drag radials
10secBu
I was wondering what some of you guys have run for 60' times with the BFG drag radial tires?
I'd like to compare notes if possible.
Please list the following...
1. tire size being used
2. rim diamter & width used
3. optimal air pressure setting used
4. vehicle weight with driver
5. best ET with DR's
6. best 60' with DR's
7. launch type...footbrake or t-brake
8. trans & converter
9. rear gear ratio
thanks for any and all input.
Todd
1. tire size being used 275/60R15 BFG
2. rim diameter & width used Stock T-Type 15 X7 3.75" BS
3. optimal air pressure setting used 16 - 18 PSI
4. vehicle weight with driver 3605 lbs
5. best ET with DR's 11.53 @ 118 - TA49, Blues, big neck IC, 23 PSI boost
6. best 60' with DR's 1.65
7. launch type...footbrake or t-brake Foot Brake, hold 5-7 psi, mash gas, release brake
8. trans & converter Stock & Stock
9. rear gear ratio Stock 3.42
1.275/60 R15
2.Weld wheel,7in 3.5 bs
3.16psi.
4.full weight regal with spare tire
5.12.30@110
6.1.7760ft
7.footbrake
8.stock
9.stock
Thanks for replying fellas. I guess I'm not doing too bad with the first outing on drag radials then.
1. 325/50-15
2. 9.5" x 15 Convo Pro
3. 18 lbs
4. 3600 lbs
5. 10.96
6. 1.52
7. 2000 rpm footbrake launch
8. th400, 8" ATI Treemaster
9. 4.10 gears
These runs were following converting my car from strip only to street/strip (sorry, not a turbo car rather a nose heavy n/a pump gas bbc). The exhaust was complete including a Dr. Gas X-pipe, 20" long case Dynomax mufflers and 3" custom tail pipes over the axle and exit behind the rear tires.
Funny thing is my best 60' previously was 1.47 in a 9 x 30 Hoosier radial slick, running a 10.66 ET with a shorter race exhaust & Straightline Perf mufflers...typical 60's were in the 1.49-1.50 range. DR's were quite close to thoe previous bests in 60'.
I'm quite impressed with the drag radials...can't wait to get on a better track surface this fall with better air conditions. I'm hoping to run mid 10.80's in full street trim.
anyone else car to share the DR combos/performance?
1. tire size being used-------------------- 235
2. rim diamter & width used------------- 7" stock T rim
3. optimal air pressure setting used------- 24 psi
4. vehicle weight with driver------------- 3620 lb
5. best ET with DR's------------------------ 7.97 1/8th, basic mods
6. best 60' with DR's------------------------1.71 on that run
7. launch type...footbrake or t-brake------- foot, same as UNGN launch
8. trans & converter------------------------ stock w/Level 10 shift
9. rear gear ratio --------------------------- stock 3.42
No big burnout, just spun them over a bit to clean them off. See my posts here:
DR Launch
9. rear gear ratio
Todd
1. 275 50 15's
2. 8inch welds
3. 18 lbs
4. 3800 lbs
5. 7.69 @ 90mph convertor locked 1/8 mile
6. 1.75
7. Footbrake Launch @ 10lbs
8. Stock & Stock
9. 3:42
just the post I needed
hey 10secbu, whats in the bbc ? what does your car weigh? what suspension- stock/ ladder bar/ 4 link? I have a 55 chevy with ls6 ,400 turbo 4500 conv, ladder bar c/o, mini tubbed, just bought some 325/50 dr's, and am wondering what setting the ladder bars should be set at (top holes, middle , lowest?) running 3.73 gears, I hang around this site because , the cars for sale or trade for a gn, also just bought some lighter rolling stock , weld pro stars. Thanks for any input in advance.
Re: just the post I needed
fasttimes,
My bbc is a destroked 427 bbc (414 ci) that has mild prepped 781 large oval factory iron heads, small Comp Cams street roller grind, Vic jr intake and an old 850 Holley. The engine runs on pump gas, and the cars weight is 3600 lbs w/driver. The rear suspension is simply the GM 4 link setup with simple bolt-on upgrades and a Wolfe RaceCraft anti-roll bar. The trans is a th400 with an 8" ATI Treemaster that flashes to 5200 off a footbrake launch.
Sorry, but I'm not much help on ladder bar setups as I've never intalled them or run them myself. If it were me, I'd probably start in the middle hole and tune from there.
good combo
10secbu, man thats a good working combo, I'll be happy if the car goes 11.50s. You are hitting the tires harder with the 5200 convertor so there is hope for me. I am running an extreme energy 284 hydraulic ( comp 242/246 @50 -590ish lift) cam, never been sure if rollers were worth the money. What do you set your total timing at? mine is at 35 degrees right now, also I had a compression test done and I have 185 to 200 psi throughout the cylinders got any thought s as to how these values relate to setting total timing, if any? Thanks
fast times,
I've only got 4 passes in on the DR's currently, so it'll take some time to learn what they like and don't like. I made 3 passes with a 2000 rpm footbrake launch which worked fine (I launch at 3000 rpm on footbrake with radial slicks). I then tried a 2500 rpm launch and rattled the tires pretty bad on the last pass with the 60' dropping from 1.52/1.53 down to a 1.69 shaking past the 60' timers.
I run my ignition timing at 38 degrees total. This is running on 93 octane pump gas. You'll simply have to experiment to leanr what the engine likes and doesn't...same way with the tires. 35/36 degrees would be a good place to start.
what kind of mph with your 1/4@10.6's
Originally posted by REGALTURBO
1.275/60 R15
3.16psi.
5.12.30@110
6.1.7760ft
7.footbrake
8.stock
9.stock
Re: what kind of mph with your 1/4@10.6's
Originally posted by Quint
Quint,
Were you asking me, or TurboRegal?
If you were asking me what my mph was on the 10.66 pass, it was 125 mph.
If you were asking someone else, please disregard my reply:eek: .
