85begalttype
just a v6
- Oct 22, 2008
trying to use the diagram to swap gn dash harness into a cutlass dash. everything is straight forward except for the instrament cluster. i want to make sure all the wiring is the same because the plugs are different. i need to cut/splice to make the cutlass intrament cluster into the gn harness instrament cluster.
i have a good source for the cutlass instrament cluster but the GN off the website is very hard to read the pin numbers and colors. Do you think it will be easier to read when its printed on paper, because i try to zoom in and its just as blurry.
Wiring Diagrams
Wiring Diagrams
