Dash wiring questions
oldsracer
Identity Crisis
Does anybody have a picture of the wiring harness that goes from the boost/tach gauge in the cluster to the main dash wiring harness. The guy I bought the dash from so kindly cut the plug off but more of an issue is the wire colors don't match the existing harness or any wiring diagram I can find. Anyone have an idea?
Do you have this one?
I have one that reads the same exact pin outs. Here's what I'm working with,
Wires coming out of cluster;
White
Gray
Green
Brown
Black
Yellow
Red
Black (Yes, 2 blacks and neither look stripped)
Wires coming out of dash;
Pink/Black
White
Brown
Grey
Black
Grey/Black
Green
Black/White
Ok I have NO IDEA what that is coming out of your cluster!
The tach module connector is located on the far right lower corner of the dash bezel. My be jammed out of the way by the previous owner.
So gotta give credit where its due, you figured it out. The bottom of the first picture has the same colored wires I have. A quick google search and it turns out its a calibrated boot/tach replacement kit sold by Caspers.Thanks again man!!!
Maybe this will help.
