I've always done mine with a normally open 4th gear pressure switch. I have had great results and never had any reason to think I needed a vacuum switch or any of the other more elaborate systems. I've done this on my last three 2004R's and it is very simple and works great. Get a normally open switch from a GM dealer. Hopefully somebody will chime in with the part number or I'll get it tomorrow at work. Install it into the VB. Take your TCC solenoid and leave the 12V+ wire as is but cut the ground wire and solder it to the wire with the plug going to the pressure switch. Remove the other unused wires from the case connector plug. At this point you should only have the 12V+ wire at the case plug. Give the wire 12V+ ignition, not constant power but run it through a good quality relay that kills power to the solenoid whenever the brake pedal is pushed. There are plenty of good write ups on this and most will give a wire diagram of what I'm saying. I'll see if I can find the link that I first used for this when I get the switch part number.
