Best headlight upgrade
Warp6
Mine since '92
I'm sick of looking...who's got the best headlight kit available for our cars?
While some may argue as to the best I believe the system we sell is the best value and doe snot pose any issues to the electric system nor blinding on coming traffic.
It sells for under $150 gives you four glass headlites plug and play harness with two 80 amp relays and is far superior to the primited sealed beams now in our car. we also have a kit for the analog dash which sells very well.
Our headlite system allows you to interchange even higher watt H style bulbs which is the trick as your sealed beam you got no real world options that make a hge difference.
again just my thoughts its in my car and I would not market it if it did not work as stated.
denniskirban@yahoo.com
If your going for bling factor (HID, LED, Halos, sealed beam conversions) THEY ALL SUCK!!!! Lighting characteristics need to be engineered. No one cares about engineering in the bling world. Real people need their lights to actually work.
If you want nice bright normal headlights then just order Kirban's.
Otherwise, you end up like me. Messing with lights for a year till you get them acceptable.
