There should be no play in the crank pully. The if it's in and out play, your balancer bolt may be loose; if it's back and forth, the key may be compromised. Either way, it needs to be fixed. Take off the IC fan and check the bolt. Don't just check it with your hand. Put a wrench on it and make sure it is tightedned to at least 210 ft pounds.
