i think he meant mm not mil
+ offset is deeper backspace pulling wheel in toward frame , - would push rim out
+25 mmthats +1" from CL
sounds like its a vette rim
on a 10" rim the cl is half the rim width (10.5") or 5.25 BS to center and then the offset of +25mm which is 1" additional puts the rear rims at 6.25" backspace
most trying to squeeze in a 10" rear rim would end up around 4.5 to 5" BS to get as close to the frame as possible ...those that dont hug the frame ...well those tires stick out and look like azz , i notched my frame to run a 10" wide 5" BS 275/60-15 mickey pro , without the notch it needed a 1" spacer
the answer is NO those wont work without an adapter , ideal without a frame notch for rear is around 4.5" and even that will vary from car to car depending on frame position , axle center and tire buldge over the rim and tire over height
stock height on the GN was 26.1"
8" rim with a 4" backspace fit pretty well front and rear and if your fronts are +25mm (9.0" rim cl is 4.5" +1" ) they will have 5.5" BS
