X xclrate Member Joined Feb 26, 2005 Jan 2, 2015 #1 Anyone have pics of theirs installed? Trying to figure which way to run it. Thanks
E earlbrown runs with scissors Joined May 26, 2001 Jan 2, 2015 #2 What do you mean? The canister slides over the filter and the inlet faces the hole behind the headlight. There's really only one way it'll work.
X xclrate Member Joined Feb 26, 2005 Jan 2, 2015 #3 earlbrown said: What do you mean? The canister slides over the filter and the inlet faces the hole behind the headlight. There's really only one way it'll work. Click to expand... Hmm there just doesn't seem to be enough room. Ac lines are in the way. They go over the top or underneath it?
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Jan 2, 2015 #4 relocate the emmision canister to the frame or under the wheelhose (there was a bracket to do that with the original kit) ac lines go over it
X xclrate Member Joined Feb 26, 2005 Jan 2, 2015 #5 Aha that makes sense. I wish there was a pic of this setup. It looks like the mass air meter sits too high to connect up to it. And the ac lines sit pretty low. Hmm thanks fellas. Sorry to be a pain
E earlbrown runs with scissors Joined May 26, 2001 Jan 2, 2015 #6 The MAF attaches to the filter and you get rid of any mounting brackets that hold it.
