ASC drawings for GNX trans cooler
Rich Gio
You'll need a bigger Hemi
Can anyone tell me where to find ASC drawings for bracket placement and mounting for trans cooler? I just scored the brackets off eBay ! Now I need the trans cooler and lines lol. Wonder if I can use these bracket to mount another style trans cooler ?
The brackets fits in existing holes in the vehicle and are designed for M6 J Nuts and Bolts.
The brackets are designed for the GNX cooler ...not sure if you will find another to fit but you may...or you may need some modification to the brackets .
Thanks Rick. I don't want to modify the brackets. I won't use them if other coolers won't work. Are they worth much?
I really do not know how much they are worth....
That's interesting. I never knew there was a such thing as a "GNX bracket".
When I put my oil cooler in, I used a piece of metal out of a big screen TV that held the fresnel lens in place....
looks like we were on the same page. :)
Found this on gmpartsnow.com says it is discontinued
(3058200) OIL COOLER ASSY - 1989 Cadillac Seville
Although not an original GNX set up, I ended up going this route instead as it looked like a well engineered & very professional looking set up that was readily available. :)
Super easy to install & included very detailed pictures & installation instructions. Have had it installed for the past few seasons & works extremely well.
http://www.ebay.com/itm/Buick-Grand-National-Custom-Transmission-Cooler-Kit-/320963230858?vxp=mtr&nma=true&si=I35p2Naq0180g2XvgVghGOxwhEU%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
