That was the simple answer, now if you REALLY want to know, put on your thinking cap and check this out.
Intercooler Theory
My head just expanded, contracted, then exploded.
I have owned both, and yes noticeably faster. The torque curve in the H/A cars is great, they get up and go. The I/C cars are just more advanced and that get's put to the pavement.
Clean-up on asile 7
Simple answers for a simple questionAre the intercooled cars faster than the HA cars? YES To go faster would be cheaper to just buy an 86 or 87 turbo car? YES[COLOR]
i can vouch on the 86-87 being faster. but stock for stock there really is only about a 1 second difference.
i dynoed my stock 84wh1 this past weekend. the only mod is the cat is gutted due to it coming apart and causing a no boost issue. It still has the stock exhaust.
the first pull was 144. hp 260 tq @ the rear wheels
The second pull was 185hp 300tq the only change that was made was the maf sensor and elbow was removed from the air box.
So that tells us how bad the air box assembly is. It has a paper filter in it too.
so the next this was we removed the lower half of the air box and just had the air filter and the top of the air box and the the maf sensor and elbow hooked up just like stock.
doing that netted 177 hp 292TQ. so i'm sure there will still be a gain in using a k/n filter and still leave the lower air box off. Doing that leaves about 3 inches of the filter exposed all the way around.
so i really think the 84-85 car were underrated too................
the boost was 12-13 psi.
Go get-um hot-air
