crownvic96
- Jan 31, 2005
anyway to test the actuator? car overboosts
right now i have a terry houston 3" down pipe, stock turbo, stock actuator and a RJC boost controller plumbed directly between the compressor and actuator. the car always overboosts. i checked the arm on the downpipe and it opens and closes with no restrictions.
the only two things it can be are either the stock actuator has a leak of some sort and isn't opening or there is a minimum limit you need to tighten the rjc controller down before it starts opening.
so is there a way to test the stock actuator? and is there a minimum i have to adjust the rjc controller down before it starts to work?
