m3x1c0
Bad luck Buick
No not the brown kind
Tuning with my Maft Pro and extender pro chip. Ecm is in full time open loop, maft is closed with an lc1 wideband. Still struggling to understand the thing. I tuned the mainscale to lowest average correction factor at cruise. This is tough to do in the hills of virginia. Seems the loads probably change when going up hill vs. down. Main issue I have is that I feel like I'm pulling too much fuel. Mainscale for these logs were set to -10. Before I was seeing almost no correction at parking lot speeds and driving out of my subdivision. Once I got on the highway and in town above 40 I was seeing the computer pull tons of fuel on the maft-pro screen. Now according to these logs it looks pretty good but while idling I'll see it slowly creep up to adding 10 percent fuel. Added 25 to lo load at low rpms and it still seems to want more fuel according to the maft screen. beginning to think it is not as accurate as the PL.
Either way. as you see I never saw WOT since I saw 12's at around 10-12 psi and she is overboosting still. (have the solenoid set for 17 psi. will shoot to 20 in a blink and turbo has seen up to 30 on this car) Any other suggestions?
(the file from the 15th is just a couple burnouts getting rid of old tires but you see how my idle has creeped up a ton. this is adding 25percent to lower loads.)
