SC&C basics package (Set of 4 bilstein HD shocks, helwig front sway, pro tour rear sway) -1109
SC&C stage 2 kit(adjustable uppers, upper and lower howe tall ball joints etc) -679
That gets you to 1788. Spend the left overs on a gnx body mount kit. That will out handle the kit you already have setup. The frame brace is unneeded unless you are putting insane power to the ground, basically if you have a stock rear end you dont need them. The rear upper and lowers are also unneeded at the moment. This gets you over where you were handling wise with premium parts and lets you upgrade the other things as needed.
