there easy to find and couldnt be any easier to install. heres one but im sure all the vendors on this board have them GAUGES, GAUGE HOLDERS and RELATED PARTS
sharp, did it include the adapter fitting for the schrader valve?
Fuel pressure gauge on the fuel log doesn't do much except for verifying you have fuel pressure and for setting initial pressure but doesn't help you when you need it the most - under boost conditions. Hood mounted or temporarily taped to windshield as previously stated is the way to go.
Be careful if bringing fuel into the cockpit. Hopefully it has an electric transducer.
x2 Excellent advice. I had cheap rail mount gage that was inaccurate. I struggle to find my rich problem for long time. Get good gage with hose so you can verify pressure while driving. Once you’re done with your check tuck it back under the hood and leave it alone. Plus this setup looks sooo cool.
