Anybody have pics of 15x10s with 4in BS on a Gbody?
muddin'metal
Thinking about moving up to a 295/55/15 mts and feel the need to move up to 10in rears. I would like to see a some 15x10 wheels pics on a gn with no frame notch, Thanks
Without a notch I think they will stick out. Pretty sure there are some pics in the wheels/tires section.
Peter is right this won't fit in the wheel well and should only be tried
if you are going for the "raked look".
too big don't waste your time and yes these are 15x10 with 4 inch BS no notch
Weld makes the Aluma-Star in a 15x9 with 4 inch backspace. Those might work better, although you'll probably have to roll the fender lip.
Here is mine with a Hoosier 275/60 on a 15x10 with 4.5" backspacing. The frame is notched and the rearend is narrowed around 1" on each side. Other than jacking the rear of the car way up, there is no way a 295 on a 4" backspacing wheel would fit on a stock width rearend.
heres more pics
I've seen JR. car in person and they look great. I have the same wheels but 17x8 and looking to move on to 17 x 9-1/2 for rear.
Reply
15 x 4.5 using 275/60/15 DR's fit perfect. fender wells trimmed as insurance using saws all
fender wells trimmed !
Right & left fender pictures, Wheel well moldings trimmed also. Looks stock.
Reply
Sorry, I see I screwed up on the wheel dimensions. They are 15 X 10 with 4.5 back space.
