As some of you may know, I ruined the ring and pinion in my TTA about a month ago at the drag strip. After pulling it apart, I found out that a previous owner had swapped in a weak 10 bolt rear end. I am looking for a complete 9 bolt for the car and I was just wondering if anyone has changed their gear ratio and if it gained them anything? I used to have a 1987 IROC-Z. It had a 9-bolt with 3.45 gears and I have also seen 3.73's offered through vendors. It seems that someone told me that a gear ratio change is not worth it in these cars, but I am just curious if this is true and if so, why? Thanks in advance.
